simoneau10
should i go spend a bunch of money on a good computer and a stock sound card, or a cheap computer with an expensive sound card? also laptop or desktop? and 1 or 2 screens?
Double that and add a bit, and you get to what I have. Trust me, once you start adding them it just makes sense to have more and more and more......I would use the generic one that came with the system... as long as it has a mic input you should be ok. You will need a mic cable that converts down to that size or a mic pre that allows that type of output. Your monitors will require a cable conversion as well.. but that's not a big deal... Most important is cpu, hard drive, and ram.
!)). The Core i7 systems have triple-channel memory controllers however, so in that case 3gb does make sense (or 6gb)...Sorry dnkygirl, I have to disagree with what you say...
I'm too tired to write why I disagree at the moment, but I do, and enough so to make me frown a bit when I read it
There's a good chance someone else will probably disagree with you, so I'll leave it up to them to justify and explain it.
Now, sleep time.
Oh, and 3gb of RAM in a Core Duo system is a bit strange, seeing as all the chipsets / memory controllers I know of run in dual-channel mode (so having an unmatched 2+1 set would probably cause a noticeable performance hit, as opposed to 1+1 or 2+2 (or 1+1+1+1 as I have!)). The Core i7 systems have triple-channel memory controllers however, so in that case 3gb does make sense (or 6gb)...
