As this is The Rack section can I assume bmg that these cables will run to 'fixed' outboard equipments? If so I can save you even more money!
Don't for a start use heavy duty 6mm (1/4") OD 'mic' cable. 3-4mm foil screened two core cable works just as well* is cheaper and, because it uses a 'drain wire' for ground, is a dream to strip and solder. It is more than flexible enough though of course it will not take the abuse a singer gives a live mic cable!
Then, superb though they are it is a waste of money to use Neutrik connectors when that will live forever round the back of the kit with the dust and spiders. You can buy 5 or more perfectly serviceable TRS jack plugs for the cost of one Nuke. Same for XLRs. Yes, the better plugs have better cable retainers but the intelligent use of shrink sleeving can counter that.
Get a test meter that buzzes, save loads of time. Get a 50mm table clamping vice and use one XLR plug to hold its mate while you solder.
DO buy a decent solder station at about $50 You can also still buy 60/40 Lead Tin solder. Much easier to use than the cheap versions of Lead free.
*In fact, foil screening is superior to all others especially at keeping RF out.
Belden 8761 equivalent for low voltage analog signals, low voltage digital control, line level audio, computer communication and panel wiring (MPN: SFX OSP1-61 (8761) LSZH 100M) (Model: SFX OSP1-61 (8761) LSZH 100M)
connectec.uk
