B
boyceman
I have an ABIT7 MAX3 motherboard and bought a new case today so I could build my dream DAW. The case states its "ATX" compatible and the motherboard is an "ATX" motherboard, so I'm thinking I'm off to the races. Well it turns out that the case is designed with a pull out motherboard tray that has a 2" by 2/3" latch on the side to "release" the tray from the case. Problem is that this lovely latch blocks the IDE2 port on the motherboard. Furthermore, there is one mounting peg that doesn't have a matching hole on the motherboard, and the pegs are fused with the tray, so removing one would require a bolt cutter or maybe a sledgehammer (I'm at that point).
Mouting pegs aside, I have two IDE drives, an 80 and 250 gig, and I wanted the 80 for the OS and programs and the 250 for recording. But I'm thinking that each drive should have its own IDE channel otherwise what's the point, two IDE's on one channel would result in a time-slice situation, no? So my next thought is maybe I should return the 250 IDE and get a 250 SATA as those ports are not blocked on the motherboard and are available.
Am I right in thinking that hooking both drives up on the same channel would negate the throughput benefits of having them on different channels? If you were in my position, would you try to cut off the bastard peg that doesn't fit, or would you try to seat the motherboard and have that end of the motherboard slightly sticking up in the air? I checked underneath the motherboard where the peg would rest and I don't see anything that the peg could come in contact with and short anything out, but who knows? Crap, I remembered I also have an IDE CD writer to hook up so I'll definitely have to go SATA on one of the hard drives. CRAP!!!
The motherboard is not returnable so I'm kind of stuck with it.
I'm bummin right now. Thoughts?
boyceman
boyceman
