WelchRecording
Thank you for reading, as this problem is currently messing with getting a professional level of work done in my garage studio.
I'm using PreSonus Firestudio Project via Firewire as my audio interface and everything works properly except that the audio being outputted to the Firestudio when I'm recording with Ableton Suite 8.0.3 glitches every ten or so seconds and is very bothersome. I've done a lot of research and found that the problem may be that my computer is not fast enough to support the device, but according to Ableton's required specs I should be fine:
ASUS A8N-SLI Motherboard (Socket 939 - prevents me from upgrading my processor past an Opteron 185)
AMD Athlon 64 X2 3800 Dual Core Processor @ 2.0GHz
2 GB DDR-333 RAM (Motherboard does say that it supports DDR-400, however)
I'm planning on spending over $400 to upgrade the processor and memory of the computer to a AMD Opteron 185 @ 2.6GHz and 4.0 GB RAM DDR-400, but before I do this I don't want to be an idiot and have the problem be something software related.
I've noticed that Ableton 8.1 has been released and would upgrading my software to that version fix it or is it simply hardware related?
Thanks for reading, hope this will help solve my problem.
EDIT: I'd misread the PreSonus system requirements when I had checked them a month or so ago and it does say that a processor of 2.5 GHz is *Recommended* so is the one-main-problem that I need to fix?
