minofifa
I thought this might have been a problem because i was using a tascam us-122, but now that ive upgraded to a 828mkII, i'm still having this same issue:
basically, i can't decide where to set the trim on my preamps when recording. I usually try to set it so that the meters in sonar are as close as possible to clipping without actually clipping. this usually backfires when something loud comes in and the whole track is wrecked do to a clipping noise. I always though that recording as loud as possible was the right way to go so you get the most headroom when mixing. Should i just be setting the trim way lower when recording, and settling on a quieter mix?
Is there any way to fix that clipping noise when you clip? i.e can i compress the crap out of it or limit the track to remove it? or is this a bad idea generally?
thanks for any adice at all.
