spitzer
EDIT: VERY IMPORTANT:
NO ONE, AND I MEAN ABSOLUTELY NO ONE IN THIS THREAD HAS SAID YOU SHOULD USE POLYSTYRENE PRODUCTS FOR ANYTHING.
PLEASE DO NOT "line your studio walls" WITH POLYSTYRENE. IN CASE IT IGNITES, THE BURNING FUMES PRODUCED ARE TOXIC. YOU COULD DIE.
Thank you.
Hi.
Don't be alarmed. (and WARNING: scientific type question)
I've been reading (very) conflicting things, on several forums, about this for quite a while now. Some people will simply say "no, it will absolutely not work" while others will say "it could very well work, don't see why not (although haven't tried it)". All of these people are what most of you'd call experts.
I'm talking about using EPS sheets in sound reduction. Yes, you read that correctly. As far as I've been able to determine, EPS has a density that matches that of some types of mineral wool. So, let's say I would build some sort of isolation wall with a frame from 2x4's, then fill the gaps with 100 mm thick EPS sheets. Otherwise the construction would be fiberboard on the outside. Now. How exactly would the EPS "not work"? How would it, in principle, be different from mineral wool or fiberglass?
I am full aware of things like fire hazards etc. and I don't care. Also, I DO understand that EPS by itself will not do much because of it's light weight (note: fiberglass or mineral wool alone won't do much either!). The physics side of this however is that once the sound waves hit the fiberboard wall, they will then enter a completely different medium, the EPS, and I'm inclined to think the sound waves would then scatter or something. What would be different here compared to mineral wool of the same density (30 kg/m^3)? I can't understand how the EPS would do "nothing" like some claim.
If you're familiar with sound suppressors for firearms, their operating principle is NOT based on enourmous amounts of MASS, but instead on forcing the sound waves to "go somewhere else". (a mass-based design would be impossible because it would be hundreds of times too heavy to handle. However very effective suppressors do exist and have existed for a very long time.)
I've used EPS panels in the past, successfully, to deal with spaces that otherwise are unbearable echo chambers. The difference is VERY evident. I believe they can also be used to construct corner bass traps, that do in fact work (I'm not interested in whether some other material would be better or "more efficient", I don't care).
So to restate the main question, is EPS functionally equal and effective compared to mineral wool when used to fill gaps in an isolation wall? If not, why? (Have you tried such a construction?)
Thanks.
Thank you.
Hi.
Thanks.
