Gavin's Song - Full Band Cover
Everything sounds real good right up to the choruses. You change to the snare and the dynamics get a little more intense but the accompaniment gets lost. I would either fade in the guitars more at those places or add maybe additional instrumentation. Also, at times the vocals kinda jumped out. Maybe put a slight limiter on them to keep those peaks in check. Otherwise good work.
Sounds nice. I think the guitars need to be brought up a bit, not too much mind you, just a tiny bit. I'd bring up the crash a bit too. I'd also add a little brightness to the overall mix, it sounds a little tarnished. I think it needs some air, that's all. Great performance.
I'd add some brightness to the acoustic. Maybe kick in some EQ around 5k-7k (it's hard to know without trying). I'd also like the bass to be a bit punchier.
I agree with the overall brightness.
Sounded pretty good to me... perhaps I'd turn the snare down a touch, and see if I could give the bass a bit more bite, but otherwise it's a pretty good mix.
Well done... :drunk:
