Hello everyone,
I have Cubase LE 4 (came with my Presonus Inspire). I also have the latest version of GPO, I used my student discount for it and got it at just about 60% off!
Anyway, when I load the VSTi into Cubase LE 4, I have to create an instrument track. As far as I am aware, there is no where else to load the VSTi.
I am not sure how to send each sample (viola for example) to a channel, and then run that channel from the VSTi track?
On the Garritan website, it says to create a MIDI track and then send the VSTi to each MIDI Channel, but I can't do this as the loading of VSTi's is different in LE 4.
My computer has fantastic specs, great CPU, and loads of RAM.
I could just create a separate track for each sample (viola, trombone, clarinet for example), but after about the third track, for some reason when I go to load the sample, GPO basically crashes (where I can't choose the instrument sample I want to load, my mouse runs over the options, but they are unelectable or disappear etc)...
Does anyone know what the problem is?
Is it bad that I should need to load so many separate GPO tracks? Should I be able to load all the samples within one Instrument Track and then send each sample to a channel?
Thanks!
EDIT: I have contacted GPO directly, but they are taking a while to write back...
Thanks!
