C
Cave Dweller
I'm just wondering how people are running their gain structure, especially regarding digital. It stems from a conversation some co-workers and i were having.
I guess i should start off by saying I am a live sound tech, and I approach recording pretty much the way I would set up a live mix: I set all my faders at "0", and adjust my gains until i have a pretty good mix, then use the faders to tweak the mix.
This usually means that sources that are generally up front in the mix (ie kick, snare, bass, vocals) are closer to "0" db than, say hi hat, or guitars. My co-worker argued that in digital everything should be as close to "0" as possible to get the most out of the chosen bit rate. To me this seems like turning up the gain, only to turn it down later, which is a big no-no in analog gear.
So lets strike up a discussion! I want to hear some opinions and arguments for or against either side. What do you think?
