Hi. I'm looking for some advice, please. The scenario is that I want to sometimes use headphones to monitor from my Eurorack UB802 mixer. When I do, I want my main monitors to not play (this way I can record vocals in front of my computer without the mic picking up the mix from the room monitors). On the UB802, I have to use the main mix volume AND the headphones volume to hear anything in the headphones, which means I get sound out of the room monitors and the headphones simultaneously. So before I try (and risk possible damage), I thought I'd ask what are the ramifications of plugging my headphones in the FX send and monitoring from there? I was thinking that this way I could turn the mains down and use the FX send knobs to change my headphone level.
In the manual for the UB802, here are the specs:
Aux Sends
Type 1/4 " TS connector, unbalanced
Impedance approx. 120 Ohm
Max output Level +22 dBu
Headphones output
Type 1/4 " TRS connector, unbalanced
Max output level +19 dBu / 150 Ohm (+25 dBm)
I noticed one main difference: TS vs. TRS connector
What are the differences between these connectors?
Thank you.
Aux Sends
Headphones output
Thank you.
