Freak-a-zoid
Wanted to start this thread to help out new PC recorders out there like myself. Forget about mastering, I want this to be a step by step process of the fundamentals.
So lets take a look at step 1(im assuming you have your DAW already )
Drums, the first thing i want to do is record the drums, okay dig, i got the DDR drum machine, Since they have pre-set beats i am unable to give each piece its own track so i have to record the drums on one track, I quess im correct in assuming one would get a better sound on the drums if each piece had its own track, fine can dig that but im stuck at one trak for now, it would take me months to sit there and record each piece to its own seperate track by tapping the pads. So how much difference does it make?
Would you say alot? a little or not much at all?
Okay, so i gotta record the drums on one track, so the next step is to get the correct "input recording" level
All input recordings are always recorded at 0db regardless of the instrument correct? if not, what recording level should one use for the drums?
Step 2 coming up...
Step 2 coming up...
