K
kierkegaard0
Fun cable question -- Dual 1/4" TRS mono (balanced) +4dbV to Single 1/8" TRS -10dbV
I am learning all about cables tonight. I have learned not enough to be confident, but enough to be anxious.
I want to go from:
Two 1/4" TSR mono (balanced) outputs at +4dbV
to
One 1/8" (3.5mm) TRS Stereo input at -10dbV
The source is a Digi 002r. The destination is a consumer computer soundcard. I want true stereo, hence why I'm trying to go for a Y-style cable.
Questions:
1) What is the best way to do this?
2) Can I use a standard Dual 1/4" TS mono (unbalanced) > 1/8" (3.5mm) Stereo TRS cable?
Thank you for educating the uneducated.
Kindly,
Kierkegaard
I want to go from:
to
Questions:
2a) Okay to use TS cable (unbalanced) in a fixed balanced output?
2b) Do I lose 6dbV headroom by using a TS cable (unbalanced) in a fixed balanced output?
2c) Is the +4dbV output to -10dbV input a problem, or do I simply keep the volume low on the output signal and no problemo?
2d) Is it cool to lose 6dbV headroom if the signal is too hot for -10bvB anyway?
Kindly,
Kierkegaard
