FSK question
  • Thread starter Thread starter The549
T
The549
a hack
So now I have everything on the way to use my FSK sync on my tape machine, but I have no idea of how it works in practice. Do I need to stripe a track with a time code before I record on the rest of the tracks?
The plan is Reaper timecode generator -> midi to FSK converter -> tape machine
If you're using Reaper, forget it. AFAIK it simply doesn't support timecodes.
If you can convert your project to something that can, what you'll usually do is this:
Attach the Midi->timecode converter to the last track of the tape machine, usually 8, 16 or 24, and record the timecode. The converter box itself will generally have the ability to generate a timecode itself. You record that on your tape track and then switch the box to playback mode.
Then you play back the tape and record your tracks on it - the sequencer may take a few seconds to lock up but it should follow the tape.
It looks like they've added some basic support [to Reaper] in the last few days, but still no chase ability.
