silentsky
Member
On a recent session, in addition to setting up my close mics and a spaced pair of overheads (Russian Oktava MC012's), I set up two "parallel room mics" (MXL 603'S), as recommended in the Drum Recording Handbook. I put them about 10 feet out in front of the kit and about 10 feet apart from each other, about 3 feet off the floor, with each mic pointed toward the outside edge of the kit on each side. I found that these front-of-kit mics have given me a much more powerful and natural sound of the kit than what I've ever gotten from my overhead tracks. When mixing, I so preferred the front-of-kit tracks that I ended up not even using the overhead tracks for the most part. My question is, are these results normative? If so, why don't more people do it this way instead of the conventional overhead placement?
I'll also mention that I have 8-foot ceilings, which I know isn't ideal for recording drums, so maybe that's the key. I guess with higher ceilings, you could get the overheads up much higher without worrying about early reflections from the ceiling causing problems. But then again, I do have some acoustic panels mounted on the ceiling above the kit to help with that, too.
Has anyone else had a similar experience, or prefer this placement over the conventional overhead placement?
