philbagg Just Killing Time May 6, 2011 #1 Right, I know the basics. X-Axis being Hz, Y-Axis being dB. Just curious as to why there would be two lines below 1kHz? It couldn't be a HPF Proximity effect? If so, Should it not say the distance?
chrisharris King of Bling May 6, 2011 #2 What is the chart from? If it's from a microphone spec, then it's probably from the "low cut" button on the mic.
philbagg Just Killing Time May 6, 2011 #3 It's from a U87 Ai ... Jesus, I woulda never thought the low cut would affect as much as up to 1kHz... Really??
chrisharris King of Bling May 6, 2011 #4 Yeah, I'm no mic guru...I'd be more concerned about the hiss bump, lol.
c7sus Disenfranchised Member May 6, 2011 #5 20dB across four octaves is actually pretty smooth. Moog lowpass filters are 24dB PER octave. Quack! That little bump is what they call "air".
chrisharris King of Bling May 7, 2011 #6 c7sus said: That little bump is what they call "air". Click to expand... Thanks, man. I had no idea.
John Willett Circle Sound Services May 7, 2011 #7 philbagg said: Right, I know the basics. X-Axis being Hz, Y-Axis being dB. Just curious as to why there would be two lines below 1kHz? It couldn't be a HPF Proximity effect? If so, Should it not say the distance? Click to expand... It would be the bass roll-off switch. This is for close work to compensate for proximity effect. The original would have stated this.
John Willett Circle Sound Services May 7, 2011 #8 chrisharris said: Yeah, I'm no mic guru...I'd be more concerned about the hiss bump, lol. Click to expand... That is part of the design of the mic. and the sound it gives. LDCs without this are often called "dark" sounding.
