frequency charts?
  • Thread starter Thread starter guitar ed
guitar ed
guitar ed
hi, guys.
I've been scouring the net for a chart that shows the basic frequency range for particular instruments. I found a few that show the frequency ranges for guitar, bass, french horn, etc. What I can't seem to find is a chart that shows this info for individual drum elements. Like what frequency range does a hi-hat fall into? What about a shaker or maracas? Do I really have to sample each of these and run a spectral analysis, or is there some kind, caring tech-head milling around here who can help me out? I sure would appreciate it! Thanks
ed
common stuff
i posted this same question awhile ago...this is what i've go so far.
FREQUENCY: USES:
50Hz
1. Increase to add more fullness to lowest frequency instruments like foot, floor tom, and the bass.
2. Reduce to decrease the "boom" of the bass and will increase overtones and the recognition of bass line in the mix. This is most often used on loud bass lines like rock.
100Hz
1. Increase to add a harder bass sound to lowest frequency instruments.
2. Increase to add fullness to guitars, snare.
3. Increase to add warmth to piano and horns.
4. Reduce to remove boom on guitars & increase clarity.
200Hz
1. Increase to add fullness to vocals.
2. Increase to add fullness to snare and guitar ( harder sound ).
3. Reduce to decrease muddiness of vocals or mid-range instruments.
4. Reduce to decrease gong sound of cymbals.
400Hz
1. Increase to add clarity to bass lines especially when speakers are at low volume.
2. Reduce to decrease "cardboard" sound of lower drums (foot and toms).
3. Reduce to decrease ambiance on cymbals.
800Hz
1. Increase for clarity and "punch" of bass.
2. Reduce to remove "cheap" sound of guitars.
1.5KHz
1. Increase for "clarity" and "pluck" of bass.
2. Reduce to remove dullness of guitars.
3KHz
1. Increase for more "pluck" of bass.
2. Increase for more attack of electric / acoustic guitar.
3. Increase for more attack on low piano parts.
4. Increase for more clarity / hardness on voice.
5. Reduce to increase breathy, soft sound on background vocals.
6. Reduce to disguise out-of-tune vocals / guitars.
5KHz
1. Increase for vocal presence.
2. Increase low frequency drum attack ( foot / toms).
3. Increase for more "finger sound" on bass.
4. Increase attack of piano, acoustic guitar and brightness on guitars (especially rock guitars).
5. Reduce to make background parts more distant.
6. Reduce to soften "thin" guitar.
7KHz
1. Increase to add attack on low frequency drums ( more metallic sound ).
2. Increase to add attack to percussion instruments.
3. Increase on dull singer.
4. Increase for more "finger sound" on acoustic bass.
5. Reduce to decrease "s" sound on singers.
6. Increase to add sharpness to synthesizers, rock guitars, acoustic guitar and piano.
10KHz
1. Increase to brighten vocals.
2. Increase for "light brightness" in acoustic guitar and piano.
3. Increase for hardness on cymbals.
4. Reduce to decrease "s" sound on singers.
15KHz
1. Increase to brighten vocals (breath sound).
2. Increase to brighten cymbals, string instruments and flutes.
3. Increase to make sampled synthesizer sound more real.
KICK DRUM:
A common solution is to cut out the muddy frequencies: Solo the kick track, set the EQ's Q to 1 and the frequency to about 250 Hz, and cut about 6-8 dB. Then move the frequency knob until the kick has a tighter sound.
Sound boxy?? Look to see if you have a a ton of 325 - 500Hz..
Hurting your ears? Check the 4K to 10K range. Sound really muddy?? Check the low stuff...
The analyzer will help you "see" what you can't hear.
In a VERY GENERAL sense - a pleasing final mix spectrum will be shaped a bit like a roller coaster. Small at the REALLY low end...then up the hill to the prominent bass frequencies...70 to 100 Hz then a gradual decline to the really high stuff over 16000Hz. This is of course a very simplistic explanation not a technical one.
On acoustic guitar cutting below 100hz is common
thanks you, my fellow Ohioan. You'd think something like this would be all over the place, but it's really not easy to find. I'm still gonna search for a chart, and if I have any success, I'll be sure to let you know.
ed
Thanks, Gidge. I just recently forced myself to admit that my digital recordings sound like nothing more than glorified garage tapes! I finally figured out that I'm not getting all my instruments to sit in their own little sonic spot in the mix. Kinda hoping that a little more knowledge of the audio spectrum and specific sound elements might help me clean things up. Thanks again.
ed
thanks shackrock! I've used those suggestions often. It has helped a lot.
