FZfile
OK....so I am now well under way putting this beast together and I needed to replace the mouse port/slot/cabel thing because the mobo plug is "5 pins wide" and I can only fit a "4 pins wide" plug because of these little stupid transformers or chokes or something on the mobo......(breath).......
so I go to my local Shop and find I have to "modify" the plug, which I was gonna do in the first place.......
BUT, while I'm there I pick up an inexpensive used Maxtor 2.5G 5400rpm hard drive to use as my "boot drive" as I will have a 7200 40G Maxtor for my "audio drive" because THEY say that is the way to go.
I read some where that optimal set up for audio DAW is to have:
small "boot" disk = Primary Master
CDR drive = Primary Slave
large "storage" disk = Secondary Master
CD rom drive = Secondary Slave
QUESTION 1 : Is this correct?????
QUESTION 2 : with 2 IDE controllers and 4 drives stacked
.....................................CDR in large bay
.....................................CD Rom in large bay
.....................................2.5G disk in small bay
.....................................40G disk in small bay
from top to bottom, how do you connect the cabels without tangling and are there cabels with the "drive plugs" spaced far nough apart to successfully do this??????( mine are not)
QUESTION 3 : Do the jumperes assign the default value of the device (as in Primary Master or Secondary Slave) or can that be adjusted in the BIOS or Devise Manager???????
I'm not sure of the jumper settings for the CD rom (used) or the 2.5G disk (used).
Any help will help.
I'm such a joneser that I just want to give all my parts to "the computer people" to put together but I should learn about this stuff and not remain reliant on the "people who sell me stuff" to
do it for me after telling me that I have to upgrade everything or it just wont work.
Thanks
-mike
Any help will help.
Thanks
-mike
