Chilli_D
I've been looking around for a little while for some decent and affordable mixing monitors. I've heard good things about the Fostex brand and I found a pair of PM0.4W monitors for $150. I'm not sure if I can trust that price however. To be honest I don't know much about what I should be looking for/need. That's why I came here
Here are the specs/info from the website:
Can anyone offer any advice for or against these monitors? Also are there any others you could suggest for under $200, I figured this would be the place to try and find the best value for my cash.
Thanks in advance!
Packing a serious amount of performance into a compact package, the 4", 18W PM0.4W powered monitors feature the Fostex focus on sound quality through advanced technology. They make excellent desktop monitors for the small, home computer-based studio, or can sit comfortably on the meter bridge of a professional console as mix reference monitors. Or, you can use the PM0.4W for fixed installation in coffee houses or restaurants.
Biamplification:
The PM0-4 monitor features internal bi-amplification employing two state-of-the-art amplifiers which are precisely calibrated to match the performance of the drive units and utilize high quality discrete bipolar output devices:HF 18w, LF 18w. High-capacity power supply units are used for excellent transient response. PM0.4 offers TRS and Line inputs
High-Frequency Tweeter:
The soft dome tweeter employs Fostex's UFLC technology (Poly Urethane Film Laminated Cloth) to achieve high-performance stability.
Low-Frequency Driver:
The 4" woofer uses a mixture of cut and milled fibers made from aromatic polyamide, impregnated with resins to simultaneously achieve high rigidity and optimum damping. An olefin film is thermally adhered to its surface to control frequency response and ensure reliability. Distortion is minimized by the use of an ultra-pure copper voice coil.
Fostex PM0.4W Powered Studio Monitors White Specifications:
* Tweeter: .62 (16mm)
* Soft Dome
* Woofer: 3.93 (100mm)
* Aromatic Polymide
* Frequency Response: 60Hz To 30khz
* Low Frequency Cut-off: 60Hz (-10dB)
* High Frequency Cut-off: 22kHz (-10dB)
* Amp Power: 18W To Lows, 18W To Highs
* Amp Distortion: <0.1% T.H.D. @ 12w 4 Ohm 20Hz - 20kHz
* Amp Signal to noise: >75dB 20Hz 30kHz (not weighted)
* Dimensions: 5-3/4"W X 8-11/16"H X 7-1/8"D
* Weight: 8 Lbs. Each
Fostex PM0.4W Powered Studio Monitors White Features:
* Exclusively designed 4" Woofer and UFLC 0.65" Soft Dome Tweeter
* High efficient bi-amp drive with 18W each for LF and HF
* Independent amplifier in both L and R units.
* Beautiful glossy black front baffle
* Magnetically shielded for proximate setting to video monitor
Thanks in advance!
