So I have used Pro-Tools for a while but mainly use Cubase. I am finally sitting down and really trying to learn how to work in Pro Tools like I can in Cubase. I have a few questions I will periodically post as I run into them in Pro Tools. I have the manual so these will just be questions I can not seem to find there. Being how popular it is I am sure it must be able to do all of these things since every other daw can, I just can not find them. Please help.
I have been using both HD and LE on a G5
1) Foder Tracks?
2) I want set it up so that when I record over previously recorded audio, when I delete the new region, what was underneith it to still be there. (I konw you can pull audio with the smart tool but what if you record over an entire clip? I do not want to have to go back to regions mode and spot it back in).
3) Can you not view say volume and pan automation for 1 track at the same time?
4) How do you direct monitor off of the 002 instead of always having to input monitor?
5) I select a region to loop with the blue arrows, I then want to move my cursor so I start playing the looped region in the middle of it instead of automatically snapping to the begining of the looped region.
6) How do I select different levels of click track to go out different bus outputs (for headphone mixes etc.)
1) Foder Tracks?
