Focusrite Voicemaster Pro
  • Thread starter Thread starter metaljoseph
metaljoseph
metaljoseph
Dedicated Member
Where is the best place on my Digi 002 to connect my Voicemaster Pro.? I want the best signal so do I run it to my mic preamps then turn the digi-preamp all the way down , or do I run it into the 1/4 inputs 5-8? I want the best signal.
Your Voicemaster Pro is outputting a line-level signal, so you should bypass the preamps on your digi.
I would suggest that you use one of 5-8.
Correct. Run it to the line in, and make sure you're using a balanced (TRS) cable. Both the output of the Focusrite and the input on the Digi002 are balanced jacks.
Better yet, if you have the Platinum ADC Card in your Focusrite, run S/PDIF between the two units.
and if you don't - get one, those units are noisy enough
