how can I insert audio track without going through the master channel?
every instrument is on separate channel but all goes through the master where I have effect for all
now I just have try to insert separate record but I don't want miss it through the master effect, otherwise to have free master i must export audio and then open both in the new project
so what I did and what I got
I make copy of effects setup from master channel to the one of empty channels and give it a name "group" then remove setup from master channel and redirect all other channels to the group channel "right click on channel/Create submix to/group" and put track to another empty channel to make it separate from master
everything was good before I check the sound! by the unknown reason sound from group channel completely changed is like reverberation or hum with same limiter and same setting and same equalizer parameters and no reverb, I use reverb on other channels which is in group but they sounds completely different through the master
