R
		rimisrandma
Guest
Originally I watched some DAW vid's to get a feel for some diff DAW's.  I ended up liking Logic because it looks like I could learn my way through it.  I also watched Pro Tools, Cubase, and Sonar, and they all look super f*cking complicated to the point that I would lose interest before I got anywhere, and I do put forth effort.
Basically I want to either run my guitar straight in OR guitar into Pod XT and then into computer (interface). I would use a DAW with Motu BPM 1.5 (drum machine software I like because it is actual programming a drum machine type unit) and Amplitube 3 as a 2nd modeler. I want to do electronic metal emphasis projects SIMILAR (but not totally exactly, just an example to put minds in the ball park) to White Zombie stuff and plus or minus that a little. Like hip hop beat, metal guitar, fcop a bass tone with the guitar for bass parts...etc.
I need a laptop to be mobile, so I plan on buying a raging model, upgrade the ram to hell and back and have external drives (audio and another for library etc) etc etc etc. I was planning on a couple thousand dollar MAC so I did not have a lot of bullsh*t to deal with like spyware programs and turning PC functions on and off BEFORE you even start recording.
Is Logic (and my other sh*t) on the right track? I thought Mixcraft was a joke and when I looked into it, it looked pretty easy to learn as well and just may need a mastering program like Izotope Ozone to do simple mastering functions to complete the package. SAME WAY with Fruity Loops, I thought it was a piece of sh*t program, then I actual check it out and it seems like I could learn my way through it pretty easy (maybe, what DAW's can you "learn your way through pretty easily" considering you actually try and put forth effort and not lay down on the ground like a baby and cry??).
Thanks
Thanks
