jimistone
long standing member
I found a pair of eminence patriot speakers in the junk pile at the local music store. The owner said he would take $40 for the pair if the amp was a junker. They were in a peavey FX 212 amp cab. He rummaged around and found the power section. He put it together just to make sure it wasn't a good amp, and also that the speakers were good. The amp, at first, seemed to work flawlessly. But, after a minute or 2 it started cutting in and out....almost like a tremelo effect ecept sporatically. It got worse at higher volumes and better with lower volumes. He said it probable doesn't need much and he would sell the whole amp for $75. I gave him $50 for it. Its,a really nice amp and I would like to fix it.
So far:
I plugged in to the "power amp in" input and it doesn't cut out at all.
I reflowed the solder on the 2 guitar inputs
I have noticed 2 things...
The indicator light for the clean channel dims each time it cuts out and the gain channel indicator light flickers dimly each time it cuts in and out.
Also, there is a bulged cap that's fractured at the top and the stuffing is exposed. It's one of the 4 larger black and white colored cylinder shaped caps.
I have a good cap just like it in another circuit board, but it's gonna be a bitch to pull that cicuit board so I haven't replaced it yet.
Could a bad cap cause that kind of cutting in and out problem?
			So far:
