T
thecugga
Hi,
This is my first real mix, and I havent been doing this for very long.
Im just gettin into buying recording shit too so my setup is still pretty weak, but here it is:
im recording pearl export drums and a cheap casio keyboard
with two SP B1's, an imitation 58 on kick, and an old akg d40s i found laying around reinforcing the snare
thru a mackie 1202 (used only as mic pres)
into a delta 44
mixed on sonar 4 PE
This mix is pretty raw, with effects only on the kick and some vocals, and no eq'ing or compression or anything else.
The tune is called "second coming of foo". I think it sounds pretty good, But that'll probably be just me.
If you guys could actually check the tune out and give me some of your wisdom that would be great. Comment on everything from the recording all the way down to the actual song itself and what you think about it.
If you guys could help me out that would be great!!
Thanks!
ohya ... heres a link to the tune
www.purevolume.com/mlviiwheredreamscometodie
song is the second coming of foo (NEW)
into a delta 44
mixed on sonar 4 PE
Thanks!
(I mean that affectionately of course).
. Second, normalize the mix in soundforge or cool edit or whatever advanced wave editting tool you have at your disposal (suggest normalizing at -14db RMS). This will kinda squeeze the instruments together, and bring the volume of the overall mix up. Third, when making MP3s there's no reason you shouldn't be using VBR (variable bit rate) Find/download a free converter like cdex (what I use). Any MP3 converter that uses the Lame codec will suffice, as they all have VBR capabiltiies. VBR will increase the quality of your MP3s without ballooning the file size too much. In its current state the recording is suffering from low bit rate syndrome.
