JoshDaveJones
Hey guys I'm Josh, I need a bit of help,
I have a Firewire mixer; Specifically a Phonic Helixboard 18 FW MKII - It records multiple channels perfectly through a 6 Pin Firewire connection into Adobe Audition, but when I try to press for playback with the output assigned so that it returns to the mixer and plays through the headphones (also via FireWire) - All that I can hear is little tones almost like the click and pop of a record whilst random tones play. - The noises correlate to the wave form of whatever I'm playing eg: A solo'd vocal track - the sounds will only occur when there is vocals audible.
I would switch the audio output to what my speakers normally play through (SB Audigy - Headphones) - But it's a different device and isn't available to use when using the mixer's streams. It's an (ASIO) device (The Mixer) if that helps.
The FireWire card I have installed in my PC is a 'PCI FIREWIRE 400 CARD - IEEE1394a - TEXAS INSTRUMENTS - TI SINGLE CHIPSET'
I have been using both of the 6 pin ports connected to those on my mixer; I have tried using one 6-pin and one 4-pin - That made the PC not recognize the device on the driver software; so I used only the 4-pin connector but as soon as I switched the output; the noise occurred except 10 times worse, so loud that I'm convinced it has blown one of the drivers in my headphones.
If anyone has any idea of how to either fix the FireWire issue, or make it so that I can use both ASIO and SB Audigy at the same time; please reply.
