sync
Pending
I know that Firewire is better than USB, but is the difference significant if you are only recording one track at a time? There seem to be people who are recording successfully with USB interfaces
studiomaster said:Lots..like what? Most are probably M-box's since it's the cheapest method to run Pro tools with.
How many does it have to be?studiomaster said:Lots..like what?
Are you suggesting that people who use ProTools are so foolish that they don't even know that their USB interfaces aren't working?Carter said:But who cares about Pro Fools?![]()
sync said:Are you suggesting that people who use ProTools are so foolish that they don't even know that their USB interfaces aren't working?
Also, there are no issues with drivers becoming obsolete, because it's usb.
I can mix about 20 channels or so without problems.
Are you able to use the interface at the same time as the external drive without any problems?omtayslick said:I record on the same computer that my family uses, so 2 printers, a mouse, keyboard, and an external hard drive are also on usb.
sync said:Are you able to use the interface at the same time as the external drive without any problems?
brzilian said:That may be true on a Mac, but certainly not on a PC. Do you honestly think XP ships with drivers for your Aardvark? Do you think it will work with Vista out of the box? I'm willing to bet no.
I have probably experimented with 3 USB devices in the last 3-4 years. None worked without giving me dropouts and hiccups.
That doesn't have anything to do with USB bandwidth. All mixing takes place in software before the audio data reaches your Aardvarks DACs - all your soundcard sees is the stereo output.
