dgatwood
is out. Leave a message.
Just a quick heads up.
If you are using a FireWire interface that is driverless (uses the built-in Mac OS X drivers), you would be well served to not upgrade to 10.4.10 right now unless your device uses a BridgeCo BeBoB chipset.
I was skimming the Apple discussions trying to decide whether to buy a new MacBook Pro, when I stumbled across a thread about FireWire interfaces not working after the 10.4.10 update.
Here's a list I've compiled as best I can from skimming various forums, Google searches, etc.
Not working:
Working:
Unknown:
If you run into this, you'll have to downgrade the AppleFWAudio.kext to the 10.4.9 version. Post in this thread if you run into this problem and we'll try to help you downgrade the driver.
As I run across more reports of working/non-working devices, I'll try to keep this thread updated.
Not working:
- Oxford chipset (Behringer FCA202, Miglia HA02)
- TI Chipset (Mackie Onyx 400F and 1200F mixers, Mackie Satellite interface, Echo AudioFire)
- Misc. reports of some M-Audio devices (but no specifics, and if true, is probably unrelated)
Working:
- Presonus FireBox (supposedly, though I wonder)
- Probably all other BridgeCo BeBox devices (FIREPOD)
- AFAIK, mLan devices (FireStation, Yamaha hardware)
- Anything with custom drivers, e.g. Phillips chipset (MOTU), BridgeCo with different firmware (M-Audio), whatever Digi uses, etc.
Unknown:
- Dice II chipset (FireStudio, Alesis IO/26, TC Konnekt)
- RME chipset (custom FPGA-based silicon)
