firepod with sx2?
  • Thread starter Thread starter AvoidTheClap
A
AvoidTheClap
i can get it to playback & whatnot. but not record with sx2 for some reason.
thoughts?
Double check your input mapping from both Cubase and any presonus control panels to make sure that the proper inputs are both activated and selected.
Carter said:
Read the freakin' manual and stop getting cocky! :mad:
the manual only has for the cubase it comes with (le)
& how is asking for help getting cocky? because i accidently clicked the mad emoticon instead of sad & didn't feel like editing?
sheesh.
You can download the SX2 manual from Steinbergs website too.
i run my firepod with sl2. these are the things i have to check when starting a project.
device setup: vst multitrack - make sure that the ASIO is set to presonus firepod.
devices: vst connections - set up your input and output busses. realize that the firepods main, cue and 1-2 outputs are all on the same bus.
you may be able to get the pdf manual from the help menu in cubase.
thats where I found the 200+ page manual for LE
