So, I was reading about compressors over at tweakheadz site, and saw that I might have a problem. I plan on adding a FMR RNC (really nice compressor) to my setup. But, it needs to be added before the firebox if I plan on putting it compressed to track (which I do for certain uses, vocals in particular). This is a problem, because I use the firebox's preamps! So I was considering a couple options, and came up with adding a Yamaha MG102 10-Channel, 4-Bus Mixer. My concern is that the preamps on that are almost certainly inferior to the firebox pre's. How would you all say the compare?
What other suggestions (other than buying a standalone preamp) would you suggest?
Here's a couple possible signal chains I have in mind-
Mixerless w/ only equipment I have
mic->firebox pre->cubase->output 5->RNC->firebox line in->track
Mixer
mic->mixer preamp->RNC on insert->firebox line in->track
The mixerless route doesn't seem like it would work, as the signal's already been processed at the point of hitting cubase I'm sure, and is already clipped if it's too hot. True or not? Why not just use a software compressor?
I'm looking to use a mixer rather than just a standalone pre because it's more bang for the buck (it'd be nice to have a mixer to track drums with the firebox). Only concern being how the mixers pre's compare to the firebox.
Comments/suggestions?
Mixer
