SKYflyer
I just received my Firebox yesterday, and I got a chance to try it out today. When I recorded in Cakewalk and played the audio back, it was full of pops. I tried everything suggested in the manual; the latency is set to the highest setting (25 ms), and I set the CPU setting to Lowest. All this to no avail. I doubt this would be a cause of the problem, but I may as well mention it: I recorded audio using the Firebox, and I exported it to a .wav in Cakewalk, which I played using my computer's built in Soundblaster Audio Card. I also tried recording with the Firebox and playing the audio back within Cakewalk (without exporting it to .wav or anything) using the built in Soundblaster card. The reason I am not using the Firebox outputs to playback any of the audio is because I currently lack any devices with a 1/4 inch input, and the Firebox only has 1/4 inch outputs. Also, the blue light indicating word clock synch is a constant blue.
In another thread about this same problem it was suggested that to fix the problem, one should download a microsoft patch to fix firewire problems. I downloaded this patch, but it did not help.
My computer specs:
1.8 Ghz pentium
768 MB RAM
20 gig HD with 650 MB freespace @ 7200 RPM
Thanks for any help guys, I hope I can get my Firebox working properly.
EDIT: I just tried recording the audio data onto my ipod rather than the built in hard drive. This resulted in significantly fewer pops, however there were still occasionally pops. Does this mean that maybe my hard drive is too full and is fragmented or something? But then again, can one record from a firebox to an external hard drive succesfully? If so, I wonder why even while recording onto my ipod (which has ~20 gigs of free space and is connected via USB) there were still occasional pops...
My computer specs:
1.8 Ghz pentium
768 MB RAM
