With what limiter? If you are just taking a CD that has peaks at 0dbFS and turning up the volume out of one set of converters into another set, you are clipping something.
Why do you use a stand-alone unit? (assuming you are recording on a computer) You could easily do all this volume enhancing in the box. It would save CD's and having to burn in real time.
Because I use a tascam tm d-1000 before/after the computer. If your next question is "why?", it's because I use 8 channels for my drums and I can bring them into Logic seperately, via the RME Hammerfall HDSP 9652. I use the pre's on it to mic everything else as well. On the way out, sometimes I'll use the onboard effects to compress the stereo tracks.
I try to. Sometimes, if it seems like the mix could be louder, I'll run it back through. I try to get it right the first time around, but like I said, I'm a rookie.
Not to hijack the thread... (can you do that when you were the original poster) but after some research I decided to try about half a dozen different settings on the loudest 10 seconds of a mix. I then imported the limited portions all back into a new file and was able to visually see what each amount of limiting did. I set the max or peak or cealing control to 98% and tried various db settings from -4 to -16.
I could not only see what the limiter was doing but then compared it to the overall perceived change in volume.
In the end, I realized that though I could really push the levels up, the music lost a lot of its punch and clarity so a happy medium was best.
Anyway, thanks to all for contributing and for the education.
