Final CD and bit/sample rates?
  • Thread starter Thread starter funckyfinger
Yareek said:
There I heard it! I dug up an old acoustic thing I recorded floating 32 bit, loaded a dither at 8 bit and BAM tons of hiss and noise. 16 bit a lot quieter, 24 bit the noise disappeared into the static of active monitors cranked all the way being fed a moderate level signal.
Okay I'm not deaf :D
Hi Yareek!.....BAM.....there you go bro!!
You're not deaf at all!!
Well done!
Besides noise floor, is there a quality difference between 16 and 24?
Because a 16-bit integer can only hold a value from -32768 to 32767.
At 24-bit, those values are doubled.
But what do those numbers represent in a WAV file? Frequency or amplitude?
If it's frequency, then you think the sound would be much more accurate. If it's amplitude, then I guess it just effects the noise floor/headroom? :confused: :confused:
Amplitude.
That is significant because every time the signal crosses the zero point (twice per cycle) it goes down through the least significant bits.
Farview said:
Amplitude.
Ok.
So what kind of data type stores the frequency? Integer, Long? Float?
I guess this is determined by sample rate?
The amplitude of a a wave is constantly changing. The speed that it changes is the frequency.
All I know is when I went down to 8 bit, there was a lot of noise and everything sounded grainy, not terrible, but not clear.
Danny, based on all the info here, there and all around, there is a very perceivable and probably objective difference in quality when amplitude dynamics can be safely increased....ie 8 bit to 24 bit depth.
Though the changes appear less as we climb the bit depth 'ladder', they are still there, regardless (?)....does that work ok? :)
Lots of good info everyone, thank you so much. I'm going to start looking more seriously into my options for 24bit . I'd imagine the easiest upgrade is my soundcard but I have other things to weigh,but that's another thread. I'm sure you'll herar from me again.
