A
aevarr
Hi all. I've been planning to make some corner bass traps for my home studio. I'm following a design where you make triangular pieces of thick rigid fiberglass (or...) and stack them in the corner. So basically, cover the whole corner of the room with the stuff.
Now the question arises, which one is better for killing the low bass frequencies:
some rigid fiberglass (I suppose this Finnish stuff I'm planning to buy is that, it's "glass wool" but in stiff panels), or mineral or rock wool panels?
I have heard that rigid fiberglass would be better when it's lighter, and if it's heavier (weighs more per m^3) then mineral or rockwool would be better?
The fiberglass that's available for me weighs 17 kg / m^3 and is 15 cm thick (although the thickness doesn't matter in this design really or does it?). Do you think that would be sturdy enough to kill low bass? Does it have to be this 40-50 kg / m^3 stuff to be effective? Is the heavier wool _the_only_way_to_go_?
Thanks for all your expertise here.
