amzavareei
Hey. This amp runs pretty quiet. One of the 2 power sections isn't running, it seems. I can take it's tube out, and it's the same volume. It's not the tube, it's the socket, and it's corresponding power section. I poked around a good bit, and did a few obvious continuity tests, but can't seem to find any breaks. No caps or anything seem burned or loose. All the tubes glow, and every pin has continuity to the board! Does anyone have any hints on where I should look? Or possibly even a schematic. It's a real pain to get clear access to all the components on the board, the way everything is wired to it. Thanks for any leads.
