westgate
ɹǝʎɐld ɹǝpuǝ
no kidding. and it DREW BLOOD!!!
i was rewinding (and bypassing the normal tape path by just rewinding between the reels) a tails-out-stored 2 track tape of puccinis 'la boheme' opera, the supply reel apparently wasn't on tight enuff and 'BAM! it flew off, slicing into my nearby thumb that was providing tension betwixt the reels.
i was able to safely stop the machine and reels from spinning and then run to the bathroom for first aid.
all ended up ok, the bleeding stopped, put a bandage over the cut, got the tape rewound, and it sounds pretty good.
this otari ars 1000 has mostly disconnected normal transport controls as it's set up for an automated environment. a on/off button in the back is basicaly the most control you get with one of these.
so you have to be careful or accidents can happen.
oh yeah; and it helps to be sure the reels are on tight enough.
