H
helleeno
Hello fellas, that's me stuck again!
Major problem: I am completely unable to work with Audition 3.0 since I use Ezdrummer in it for every single purpose.
Here's the error message:
...well, I guess it will be posted righht in the end of the post.
My attempts on trying to solve the problem:
1) Repaired (not re-installed) Audition;
2) Repaired AND re-installed Ezdrummer. Second time I've done this, I've customized the installation by placing everything into Audition 3.0's "Vsti" plug-in folder. Even knowing that giving this monoply to Audition wasn't the best/right thing to do;
3) Disabled the MIDI track's sound output.
None of those worked.
Everytime it crashes it shows that message asking if I want to "Continue Now", "Delete", or "Continue Later", that session I've left prematurely. If I choose "Continue Now", no Vst is ever recognized, like there are really none installed. Should that be somewhat a clue?
I should be important to inform that I have had this problem in the past. As far as I can remember, I've fixed it by installing things correctly (toontrack folder into C:\ and ezdrummer.dll into Audition's Vsti folder), which apparently is not the present solution. This unfixingly bug came practically out the blue, since I've using and abusing this Vsti hosted by Audition for, say, around 2 months or so. Yesterday I was editing this drum map written by a MIDI controller, and after a few hours, when I opened that last sessions, bug started.
Thank you guys for reading my thread.
I'd be very thankful for any help, since I'm desperate here with tons of sessions depending on Ezdrummer to be continued.
Cheers!
Cheers!
