D
deadmansshoes
Once you drag the groove into your project you can double click on it and it opens an edit window. In this window you can move notes around and edit as much as you want.
I've been looking to create a slightly odd tempo beat and I've quantized the drum map and tried moving notes around. But is there a way to just change the tempo of a pre-set loop like you can when EZD opn normally and not through cubase.
