External preamps w/fostex recorders
  • Thread starter Thread starter gospel
G
gospel
For you guys/gals that are using an external preamps with your fostex recorders (especially digital) what are you using?
ART Tube mp for my condenser mic. Works well. I have all kinds of control on input levels for my acoustic guitar. I am thinking of getting another one to use on a second mic.
TL Audio 5001, Joe Meek VC1Q, TL Audio EQ1 (2 pres/Tube Eq), very occasionally Mackie 24-8 pres (in a pinch)....hope to soon add RNP (2), API 312(2-4) (Averill or OSA) or something "high end" (since I obviously don't have that yet!)
BW
Pinederosa Studio
Behringer Ultragain 2200
It's real nice, quiet, had phantom, plus some useful EQ.
M-Audio DMP3 and Art Tube MP (mostly just used as a bass DI).
i'm thinking about copping one of those 5 channel Behringer mixers for like $79.00 from Musician's Friend and usign that as a preamp for one of those $70 MXL condenser mics. Because then I can use the Behringer mixer to also sub-mix my drum work (when i get a drum mic set). And hell, the price is right.
I just got a Mackie 1202 that makes an amazing difference. Now I've got phantom power for condensors and pretty decent EQ. Also, I can mix 4 mike tracks into two and send them to the MR-8. I was pleasantly amazed at the sound that two MXL V63 mikes and the Mackie send to the MR-8.
Behringer MX2004A Mixer that I use for everything from Recording to Small Venue Live Gigs. I'm Looking at getting my first Condenser Mic so I'm looking at buying an Art Tube Preamp or one of the Behringers.
CR ><>
Gospel, according to Alan Hyatt, the studio Products VTB 1 will be going for $130 in a few weeks. You might want to check into that because it gets good reviews.
I'm using the Audio Buddy, which works well for me.
Used with Fostex VC-8 8x ADAT convertor
I run channels 1-8 through a soundcraft FX8 then into the Fostex VC-8. 8 channel to ADAT convertor.
I set the FX8 so I can adjust gain (attenuation), apply the 3 band EQ and then take a pre fader direct out to the VC-8. How does that sound? Considering the alternative - a mic, an in line transformer and no EQ on channel 9-14, it sounds a whole lot better.
I like to put all the drums (kick, snare, toms, floor, Hat, OH, OH) and a bass mic into the FX8 and apply channel EQ on the way into the board. This way I have good tracks that require minimal EQ in the mix. Also the Fx8 provides phantom power for the OH-OH-HH mics
Channels 15 and 16 go to a four band audioarts parametric via the insert loop. I usually run Bass direct and perhaps a vocal through those and EQ on the way in there too.
Channel 13 has an ART tube channel with an Octava 319 condensor in front of my marshall combo amp that records my Harmonica. I also use the ART tube channel for vocal overdubs with a Studio Projects C1. I like the ART tube channel and would like to get 4 more of them. I can not find much good said about it on the web, but I can make it sound good. I takes some practice adjusting it with someone else singing or playing but when done right sings.
Now to channel 9 and 10. During practice we put two Beta 58A's into our Yamaha PA and take the insert ( with a special plug that shorts tip and ring) and send it to the fostex. This lets EQ be applied prior to recording also.
That leaves channel 11 & 12 for straight recording with an in line transformer, without EQ or compression.
Female vocalist uses an AKG C3000B through a Focusrite Trackmaster. Sounds gorgeous on her, not so good for the male vox - SM58 works better for him.
All else through the trusty Behringer - works fine for us. Bass through GNX3 (which I bought for 6 string but a clean gentle compression setting works well and I can't afford a new DI box right now), guitar DI-ed from a Fender combo and, until we get a drummer, a Boss DR770.
It's all starting to come together, hope to post some music before too long.
external preamp to digital foxtex recorder
4 gtr:
either my digitech rp100 (digital preamp) or my zoom 9150 (tube preamp) trh
through my rack for effects processing.
4 vocals:
(acoustic): had best luck w/ internal condenser mic in fostex mr8.
and recorded my acoustic gtr tracks that way also.
for "experimental vocals (looped, etc)" i've processed through my
zoom 9150 on a clean tube setting w/ no effects using a
cheap radio shack dynamic mic. it worked quite well.
i might try it for some real vocals as well-i think it might work
just fine and give some punch to my "weak vocal talents".
down the road i'd like to get a decent condenser mic and one of
those art mic preamps. but need to wait for now.....
s---
Mic Pres
I am using 2 Focusrites Trakmasters which have compression, EQ. They have intrusment and line inputs in them as well. They are great for Bass guitar DI as well as many microphone and vocal duties. I also use an Aphex 107 dual channel Mic-pre for drums and other things. They matched up nicely with my VF-16 and now my newly purchased VF160. I will soon post some completed recordings done on the VF-16 and later completed on the VF160.
Cheers,
Daniel
www.meetgoodwin.com
Goodwin - how are you getting on with the Trakmasters?
I've only had mine for less than a week, and I'm a newbie so although it seems great to me I'm judging from a starting point of profound ignorance!
Will try putting my bass through it shortly.
Foscusrite Trakmasters
I actually think they have been the single biggest improvement to the quality of my recordings, besides buying high quality mics. You can go to http://www.meetgoodwin.com/audio_new.htm
and check a very rough demo of a new song using the trackmasters on the snare and kick drum and bass guitar tracks. The vocals and guitar a trash scratch tracks. I will will upload a newer version tonight with completed guitar tracks and then later again with finish vocal tracks using the focusrite preamps. I use them for everything. Is it an Avalon, no but it is a 100% improvement on using my mixer pres-or worse yet the Fostex pres. You can also check out my studio setup and such.
Cheers,
Daniel
www.meetgoodwin.com
