J
Jcpalmacarrillo
Hey, I have a question
What's the function of an external hard drive on the studio?
When I record, all the audio files goes to the external hard drive? my computer it's gonna be faster and more stable because it doesn't have a lot of audio files filling the memory? How do I save the audio files on the hard drive? Just saving the project on that hard drive? What kind of hard drive it's better for the job? (Characteristics: tb, rpm, FireWire or USB ) thank you for your answers![]()
Not necessarily though, of course, you can. When I record, my audio files go to an internal RAID5 drive in my computer because it's a lot faster loading projects that way. However, you should be backing up your data files regularly. I use software that monitors some of my drives and folders and automatically backs them up as soon as the files are changed.When I record, all the audio files goes to the external hard drive?
No, it doesn't work that way. Data storage has nothing to do with memory. Computers save recordings as data files, which reside on the hard drives. This has nothing to do with stability or speed, but with security. Back in the 80s, when I had my data disaster, I lost a show (I write musical theater) when the hard drive on my computer crashed, and I had no backup copy of the data. Fortunately, I had the audio on multi-track tape, but it's not the same as having the original, unmixed, unbounced, audio.my computer it's gonna be faster and more stable because it doesn't have a lot of audio files filling the memory?
Your DAW's preferences allow you to specify where to save the audio files. However, that isn't what it means to back up your data. You need to either manually copy the files to another drive, or use software that will do it for you.How do I save the audio files on the hard drive?
Project data is not the same as the audio files. Project data files should also be backed up -- they're what contain all the information on mixing, effects, bus assignment, etc.Just saving the project on that hard drive?
Better for what? Backup? A RAID5 NAS on your network is the best local solution. Off-site backup safeguards your data in case something bad happens in your studio. I use two RAID5 NAS devices on my LAN, with one the mirror of the other so that I have two highly-reliable and independent repositories for my data, in addition to the RAID5 internal drive in my computer. On top of that, I backup to a portable USB 3.0 drive. I use USB 3.0 because it's fast and the backups take little time to create. In addition to all that, I have at my office a dedicated computer with a 3 TB USB 3.0 drive for off-site backups. I have a dedicated computer on my LAN that does nightly backups to the office computer via VPN. There are other approaches to backup as well, e.g. Carbonite, as someone else mentioned. Carbonite is a commercial off-site backup service -- you pay a monthly fee and get a program that runs on your computer and automatically backs up your data to the Carbonite servers.What kind of hard drive it's better for the job? (Characteristics: tb, rpm, FireWire or USB ) thank you for your answers![]()
It's not a question of "which hard drive?" but, "which system and protocol?" that will afford maximum protection within your budget.
And finally, no offense, but from your questions, it sounds like you don't really understand how personal computers work. Get yourself one of those "Computers for Dummies" books, and learn the difference between RAM (computer memory) and hard drives (physical data storage) and how the computer works with the two.
Sometimes I get carried away.Whoa!! A bunch of that flew right over my head, and I thought I had a grip....LOL!
You're correct, of course. I think, though, that the poster wasn't clear on the reason why we keep data on one drive and programs and the computer OS on another, versus backups. Using separate drives for data and programs does help the computer run more efficiently and faster. It's not related to backups, though. A backup strategy is solely for safety. That means two drives in the computer, one for programs/OS and one for data, plus some out-of-computer backup system. That can be a single, external USB or something more elaborate.Easy answer, save/stream audio and project folders to a separate or external drive. This keeps your computers drive free to do what it needs to do. Backup files to another drive to avoid losing data from the inevitable/eventual failure of any hard drive. If you can, backup your OS drive so that you can start from where you left off, and not have to reinstall/register all of your software.
When it comes to computers, I sometimes think nothing is simple -- I had a nasty and inexplicable crash of Audition the other night and had a project file totally corrupted. I lost a whole evening's work (the auto-save files were corrupted, too -- thanks Adobe!). Expense is also relative. I've been working on my current project for the last 3 years or so. It occupies just under a terabyte of data right now. Losing that would be like losing an arm, so I'm paranoid -- I'd rather have too many backups than only one that failed, so I've got the mirrored NASes (one NAS is a copy of the other), the off-site backup, the portable USB drive, and a RAID5 array for data inside my music computer.Really simple and not that expensive.
Try placing the HDs in the freezer for a while. Once they're really cold, connect them back to the computer and immediately try to pull your data off. You may have to do this several times.I am currently trying to figure out how to recover years of work from HD's failing on me.
Sorry but, though that was true at one time, it is certainly not true now. Yes, at some levels of complexity, a drive may choke, but for casual use it is not a problem and, in any event, wouldn't result in corruption. Bus speeds are so great now that most modern computers can handle a huge amount of data transfer to drives. Seek times have similarly improved and, with a large enough buffer in the drive, simply aren't an issue. And, of course, with SSDs, seek times aren't a factor at all. Nonetheless, it is still good practice to keep audio and video data on a separate drive.You should never use your system drive to record audio, much less video. The system drive is constantly in use with background temp files being written and read and this may slow your audio performance, or actually cause corruptions in extreme scenarios.
Oy. First of all, eSATA means "external SATA." You meant just "SATA," which is the standard in current computers. You also meant 7200 rpm (as opposed to 5400 rpm). However, rotational speed doesn't give a true picture of how quickly a drive can read and write data. Other factors include bus speed (SATA can range from 1.5 to 6 gbps), seek time and buffer size.Ideally fit a second eSATA 72rpm drive inside your computer
It might, depending on the factors I mentioned about. There are some 7200 rpm SATA drives that perform poorly compared to some 5400 rpm SATA drives. "eSATA" refers to the type of port, not the drive. And, as I mentioned "external eSATA" is redundant.for audio recording or buy an eSATA PICe card and use it to connect to an external eSATA 7200rpm drive which will give you great performance.
Ah, a Mac user. That explains a lot.Thunderbolt is good too
That is utter nonsense. Firewire was a video standard for more than a decade, and has lost favor only because of the additional costs associated with the interface. USB 2.0 is perfectly adequate for many applications, and USB 3.0 is faster than 3 Gbps SATA and only slightly slower than 6 Gbps SATA. All these interfaces -- SATA, Firewire and USB -- are stable, reliable and will function perfectly well for real time recording.but you should avoid Firewire and USB because their system drivers are not optimised for real-time recording.
