External Audio interfaces - are they really needed for electronic based musicians?
  • Thread starter Thread starter Darryl Feldman
D
Darryl Feldman
Hi,
I am a semi-newbie and have an important question relating to my general setup and the use of audio interfaces in a mac / usb world.
My setup (hardware)
-MacBook Pro (mid 2015)
-iPad pro / iPad air 2
-External monitor
-Panorama P4 midi controller
-AKAI MPK Mini midi controller
-Blue snowball ICE usb mic
-AIAIAI over ear headphones
-Kanto YU2 mini monitors
-ROLI blocks lightpad & loop controller
-Focusrite Scarlett 212 audio interface
My setup (software)
-Logic Pro X
-Various apps on iPad (synthesizers, drum machines, instruments)
-ROLI studio
Use cases
Currently I am connecting all external devices directly via USB or in some cases bluetooth
-Connecting external midi controllers (Keyboards, drum pads, iPad) and recording into Logic
-Recording iPad instruments into logic
-Arranging and outputting songs from logic
-Recording vocals from external mic
-Monitoring audio with external headphones and monitors
Note: I do not want to record guitars or other live real instruments
Big and main question:
-What would be the main reason based on my setup to use the Scarlett 212 as an audio interface, is it basically redundant?
-If you have a similar setup do you have any tips to optimise for sound quality and ease of managing all the inputs / outputs
Thanks for any insights before I decide to get rid of my Scarlett audio interface!!
Cheers
Darryl
To get the audio out of the computer - how you are monitoring. Otherwise you would be using the Macbook's internal soundcard.
Most built-in audio I/O are ridiculously bad. If you're doing *everything* ITB, I'd still argue that even only for the monitoring DA would be worth the upgrade.
It also depends on the quality of recording that you want to achieve. If vocals are an essential part of your music, you should be using the Scarlett with a higher quality mic than the Blue Snowball. While the Blue will get audio into your computer, you're not going to get "pro" quality from a $50 USB microphone any more than you would get a quality mix by using cheap mulitmedia computer speakers vs a set of real monitors.
