thebigcheese
"Hi, I'm in Delaware."
Alright, I'm trading my Blues Jr. for a Vox Night Train, which I like much better, but it still doesn't have more than one channel or an FX loop. Neither of those seem particularly difficult to add, since all I really want is to have the same channel twice--I dig the distortion I get from cranking the gain, but it would be impractical to try to switch from bright to thick and crank the gain in the middle of a song. So it seems like basically all I'd have to do is put together a copy of the EQ/gain section and preferably also the master volume knob section so that I can have two different sets of settings, then link those to a switch that could also be footswitchable. I'm not really sure how to do the footswitch, but the rest I'm pretty solid on, except for exactly where to insert it on the PCB. Here's a link to the schematic: http://www.prowessamplifiers.com/schematics/Vox/Night_Train_Updated.html
It looks to me like I would cut the trace before C29 and run that to the switch, which would then run back to that spot on the PCB and also to my copy. The output would then go to where #2 is on V3B on the schematic. The thing I'm not sure about that is that lug 6 of the bright/thick switch goes to a separate section of the circuit, so how would I do that with channel 2? Do they both just connect there, or am I going to need diodes or to also wire that to the switch? Then the Volume section would also need to be wired to the switch so the gain channel isn't louder than the clean channel, but that knob seems to be connected two places on the schematic. Do I just need to splice in at lug 1 of the volume knob, or am I going to need to splice in farther back?
Beyond that, I also need to know how to make the channels work with a footswitch. I really have no idea how to wire that to work in addition to the amp switch. Mesas have a middle position on the switch for the footswitch, which could be nice, but if it's going to make it more complicated, I'll pass. Also, when I switch channels, am I going to have to worry about "pop" when I switch?
Finally, I really don't know where to stick the FX loop. It seems that, when adding an FX loop to an existing amp, you also want to add some level knobs. Where do I splice that in, and how would I wire it up?
Thanks. I'll definitely make sure to post pictures and stuff when it's done
