Okay so if i got this right, the more speakers you have under the same amount of watts, the earlier they will break up?
Hehe, no. This topic (watts, ohms, speakers, volume) is discussed endlessly! Someone should make a True and Final Answer and make it sticky.
Sticking to what I know, here's an example from my bass rig.
Ampeg B2RE pushes 250 watts into 8 Ohms, or 450 watts into 4 Ohms.
Using (2) two 8 Ohm cabinets, the amp sees 4 Ohms combined impedance and is pushing 450 watts total. (Each cabinet gets 225W presuming everything else is equal, which is simplistic but essentially right).
(8 Ohms + 8 Ohms in parallel = 4 Ohms, look up this separately if it's news.)
Suppose those two cabinets are 1x15 and 1x15. This gives me two 15" speakers at 225W each.
Q: WHAT IS THE BEST WAY TO GET LOUDER?
A: 1) BUY THE SAME SPEAKERS WITH IMPROVED SENSITIVITY, 2) RUN TWICE AS MANY WATTS
Some speaker cabs are rated at 90 db/W (1khz at 1 meter) and some are rated at 102 db/W. That's a 12 db difference (HUGE) using the same amp and the same setup - 2 15" cabinets. (This is why Behringer sells a 410 for $175 and Epifani sells a 310 for $1000 which is probably louder than the Behringer.)
Alternatively - If I switch to (2) two 410 cabinets, I now have 8 speakers each getting 450/8 = 56W each. Much less power to each speaker, however the SENSITIVITY of those speakers will be different, and THE SURFACE AREA has changed.
2x115 cabinets has 2x(177 in^2) = 345 in^2 of speaker surface area.
2x410 cabinets has 2x4x(79 in^2) = 632 in^2 of speaker surface area.
The 2x410 setup has nearly twice as much speaker surface area. This is critical to reproducing low frequencies efficiently. This is why standing in front of a 2x115 bass stack is really loud, but standing in front of an Ampeg
810 cabinet will disrupt your internal biological processes and cause blurred vision.
This is only indirectly related to when the amp "breaks up". In general, the HIGHER the impedance, the SOONER the amp will break up. This is just common sense - making the amp push harder will "use up" the headroom sooner and create crunch.
In general, when you're adding an expansion cabinet, you're lowering (or keeping equal) the impedance that the amp sees. If you're looking for more crunch, this is not a good way to address the problem.
And part of the confusion is the word "louder". If you add an expansion cabinet to your guitar amp, it won't be "louder" as measured with an SPL meter pointed at the speaker cone. But it will be "louder" as -experienced- by people in the same room with you (provided you followed the points above).
(As an aside - Increasing in wattage can make your guitar "louder", but you must 1) increase by about 100% to really get a difference, 2) have speakers that can handle it, and 3) be certain that you do NOT go DOWN in SPEAKER SENSITIVITY. If you only increase in wattage by a small amount, it's like adding an 11 or 12 to your output volume knob - unless you keep your amp flat out dimed all the time, this isn't a good investment and it probably isn't what you want to sound like.)
Any corrections in math, theory, or life are welcome.
