Thanks! Worked like a charm =)
Actually I did it in real time. I took the headphone out of my recording hardware (like a firepod) into channel 1 of the hardware and hit record.
Hope this helps!
B
One way to do it is to route the metronome (in the metronome setup) through some kind of midi sampler or plugin and use the output of that. Of course that will make a click track that sounds like whatever plugin you route it through, rather than the BEEP beep beep beep that the metronome gives you by default. But the beep is annoying anyway.
