grimtraveller
If only for a moment.....
Could someone, in simple English, please explain what an attenuator or power brake is in regards to guitar amp ? What is it supposed to do ?
I prefer the term "power soak" for the devices that go between power amp output and speaker. The term attenuator means something specific to an electronics engineer and generally means a device of great precision that operates at millivolt signal levels.
There are BTW device on The Bay that purport to be "attenuators" but are in truth nothing more than a pot in a tin and you can make one for a few $$/££. These are connected into the FX loop of an amp and merely reduce the DRIVE TO THE POWER STAGES. They do not and cannot work the op valves harder. NEVER put such a device in a speaker line (in fact never put ANYTHING in a speaker line unless you are dead, bang sure of what you are doing!) The pot boxes can however be useful. Some amps have such a poor "law" on the master volume control that it is hard to set a convienient level. Useful too on non-master volume amps but there are surely few non MV models WITH FX loops?
It is said that power soaks will shorten power valve life. True, but only as much as if you were removing the windows with them down the Palaise every night! It IS true that a purely resistive load* is less kind to valves than the reactive speaker but then IMexp' valves fail due to voltage flashovers these days, not of old age and so resistive is marginally "safer". (Oh! and do not ever try a PS on a solid state amp!)
*There are transformer based soaks but theses are heavy and expensive and don't suit all amps soundwise (checkout a guy called ICBM over at musicradar.com He has tried most of the PS's with many amps).
BTW. For amps of 30W and less it is quite easy and cheap to make a power soak and is a good starter DIY project if you have a smattering of soldering and metal bashing skill.
Shoot me a PM Ron and we can have a chat,You have any links to the schematics and design for one of these simple "power soak" boxes? I've got an 18w amp I'd like to make one for, and I have a pretty decent small electronics background.
Thanks!
Attenuators can also be useful on tube amps with master volume. The master volume on most tube amps overdrives the preamp section. This is not as musical to many ears as overdriving the power section. My experience is that the tube life issue has more to do with attenuators allowing you to keep your amp cranked more of the time. The volume produced may be much lower but the tubes are working just as hard as if you were peeling the paint. Be advised, using an attenuator will have an effect on your frequency response (tone). It's not always for the worse. However, playing through a tube amp at low volumes can often leave you with unsatisfying tone. It's a tradeoff.
I much prefer the reactive type. YMMV
