M
mesaboogie5050
Noob question, but I need to learn.
I know what latency is, as far as the definition but here is my question. Though, I'm hearing myself delayed in latency, is it being recorded before I'm hearing myself?
Therefore I use zero latency with my Saffire mix control on safari pro 40, and I am getting no latency in my monitors, and it's also recording on time as well correct? Just as it was recording on time with latency but I was hearing myself later?
Reverb question
If I want to hear reverb or another effect with zero latency, I know that I have to put that on an aux track, and then the track I'm singing through, I have to send over to that aux track. I have to mute the track so I don't hear myself twice with the latency in monitors.
Now, I understand, I set the aux track (or bus track call it whatever) to prefader.
This is where I do not completely understand. If the audio is muted on the channel, even if I go prefader, why will I not hear the other audio with latency? I know it's muted, but we are talking pre fader.
Is it that the latency track is being recorded post fader and that is muted so I only hear the reverb?
Also, does the aux track contain audio. For example, say it's recorded, could I solo an aux track with reverb and hear the music plus the reverb. Or does it just contain the reverb?
LAST QUESTION:
So, if I'm recording at zero latency through the saffire software mixer, should I turn the buffer size to the highest setting since I'm not using it for latency, thus getting better CPU performance? Or does the buffer size still need to be up as low as it will go? If so, explain to me why, since I'm not monitoring through that.
Because with playback, there is no latency right? Or is there only latency with playback when there are plugins?
Reverb question
LAST QUESTION:
