stayouttamalibu
ethan - i have a big question for you. so from yours and other peoples help here, ive decided what i want to do for my small mixing room as far as fiberglass. i want to put 2 inch thick 703 in the walls and ceiling, and 4 inch thick 705-FRK in the corners for bass traps. now here is my problem, i can not find a supplier of owens corning anywhere near me at all.
however, i found a home depot in the LA area that said they have two inch thick johns manville rigid fiberglass. now assuming that they have it available in 6 pounds per cubic foot, would that mean that this would be comparable to 2 inch thick 705? i would think yes, just making sure. now if that is a yes, i have a couple of questions.
1. is there any disadvantage to using 6 pcf for wall/ceiling absorption instead of 3 pcf? im just trying to work with worst case scenario here, and if they possibly only have 2 inch thick 6 pcf, i would just get a lot of that and use it in place of the 703, and then stack it to make 4 inch panels for the corners and use it in place of the 705.
2. i know johns manville has FSK, the equivalent to FRK, for some of their stuff, but in case home depot doesnt have that for whatever specific type they have, just standard without the foil paper would still work well, correct? well enough so that i should still get it if i have the chance to get this, and not waste more time just trying to find stuff with foil paper?
