I am getting an error when trying to export the mixdown to a .wav or any other file. It is only happening with one particular mixdown. Everyting else is working fine.
My bad...I guess becuase I was using the Multimix to record.
When I go to FILE...EXPORT...then run thru all the spec (where I want to save it etc) I get an error then I try to export. It only occures with this one file. I would rather not start from scratch as I have some significant time involed in this one.
I use Sonar not Cubase but...in theory you should have all your wave files from the project in a folder on your computer. Worst case scenario you could start a new project and import those wav files and stat again.
I'd probably back up those files right away too...
