Basic Setup
I posted this to a local music forum so I'll apply the old copy/paste routine for the bulk of it.
Obviously this is to do with setting up a Computer-based studio. Portable 2/4/8 tracks have everything you need apart from the mics & monitors.
Hope it helps!
Hi gang
Throwing my 0.02c into the ring; I have set up my own home studio and work in a music shop and the following is a list of basic stuff I believe you need to have in a home studio:
*Good quality sound card.
Ditch the sound blaster. Something with preamps and XLR balanced inputs with phantom to power a condenser mic preferrable (or get a mixing desk - see below).
If you can avoid using a USB-powered device, even better. The power drag on these babies has gotta interfere with the audio you're trying to pump through it. USB device with mains-power is ok. Firewire or PCI is the better way to go.
Something with two inputs will permit you to record guitar effects or synth stuff in stereo.
Go via a small mixing desk if you need to boost the signal from a dynamic mic, adjust levels from various bits of gear, power condenser mics, etc.
*Monitoring
Good (and I mean GOOD) quality headphones have given some truly excellent results for some songwriters I know, but they must be GOOD (got the picture?) Stomp on your soundblaster speakers and invest in some desktop-sized reference monitors. Even large hi-fi speakers will do at a pinch, but will colour the sound you are hearing to some extent.
*Software - LEGIT software.
Sure, we have all used cracks, but sooner or later they're gonna stuff you right up. And no shop is going to support the installation of your soundcard if the PC is full of cracked software. The real McCoy is cheap nowdays so no excuses!
*RAM
The more RAM, the happier your computer will be.
*Dedicated PC
Use the PC for music only. Use another one for the internet. Keep your studio computer virus and spyware free and don't load games on it which can clag up your system.
(Same goes for Mac users)
*Mics
Sooner or later you're going to want to record guitar, voice, Norwegian nose flute or whatever. Dynamic mic (eg:
Shure SM58) is fine if you have the ability to boost the signal (via mixing desk or preamp). Jacking straight into soundcard is going to leave you with a low-level muddy signal.
Condenser mics are the shizzle for studio recording, but you *will* need a pre-amp that can supply phantom power to it (unless it is something like the Rode NT3 which can be battery powered).
Stuff like compressors, Eqs and high-end channel strips are also extremely useful, but only once you have got your head around the basics of recording and can understand *why* you need them.
The great thing about setting up your own home studio is that you can fool around in there and learn how to record and mix everything yourself. Sure, you'll make mistakes and it might take a while to get your head around how everything works, but that's all part of the fun.
Good luck, and happy recording!
