T
tf5_bassist
The LouDogg
Hahahahahahahaha!!! That's the funniest geek humor i've seen in a loooong time!
And I clicked on it. Perhaps I should register that domain before someone else does.
knightfly said:(joke) BTW, when shopping for a BS filter, remember that all filters are not created equal - for example, a cheaper passive BS filter just slightly rounds off BS and works only on fairly runny BS. With a more expensive ACTIVE BS filter, you can get up to 24 dB/octave slope, which results in sharply defined, crisp-edged BLOCKS of BS, quickly lowering in level to 0 BS. This would equate to a SPL (Shit Pressure Level) of less than ambient. Sooo, if you lived in a really shitty place, it would be a waste :=) of money to invest in a 24 dB/octave BS filter, because your surroundings would prevent you from ever knowing how well it worked. The only advantage then would be "bragging rights", which would normally require their own High-Q BS filter to limit levels of public disgust...
Now, for just a lot more money, TC makes the ultimate - the "SANITIZER", an all-in-one, do everything well, "royal flush" of BS filters. The Sanitizer is capable of separately filtering BS, CS, DS, GS, HS, MS, and even PS with the optional "humanizer" plug-in... for extreme conditions, there is also an optional oversized output to which you can connect a 6 inch sewer pipe. this saves several cycles of intermediate processing, and improves drastically on the "bypass" mode. Space does not allow a complete "run-down", but more can be found at www.U-B-FULLA-POOPIE.com - "no affiliation, I just use 'em"... Steve
