EQing Guitar
  • Thread starter Thread starter Ignition.
Hey ya'll,
Hear the water to wine bit.
I do have a 58 and that's what I've been using.
I guess I'm just a real newbie or something...thing is, I've read like three books on recording and technique, and been doing it (actually recording stuff) for about a year, (musician trying to make my own albums) talked with everybody i can think of...and either I'm stupid, or just have bad hearing in the booth. I've messed with mic placement to hear the diff frequency responses, and yes, on guitar I too used to outboard EQ and Compress as the signal went to the recorder (I stopped that a bit ago)...now try to rely on mic placement to get the tone...my problems are many...geez...where to begin.
In a nut shell, I do understand that one can not make a practice amp sound like a marshall...but I can't even get a good distorted sound. It's either too tinny and shrill, or to flubby and loose...I just want a nice tight distortion...will try boosting the master, and taking off the gain...but onto bigger aspects...my recordings sound muffled...to combat this, I've been rolling off the bass freq on a lot of instruments...but I have trouble finding the right mix cause then it gets to crisp and shrill.
I know it sounds like two different issues...getting the right guitar tone...and getting a crisp clean overall mix...but I know they are related...it's like my ear hears one thing, then when I actually sit down to listen to the mix, it's not at all how I pictured it...the guitar sounds to shrill, or not shrill enough...but when i listen to it soloed it sounds great. Now, I know, you must fit things in the mix...and I've done that, I give each instrument thier own perametric EQ freqs to let them come through...but still...the final mix is almost almost muddy...or shrill when i roll some bass freqs off the different instruments.
Any suggestions on that??? I've heard to be very carefull when boosting 200-800 Hz cause they are all big offenders of muddiness...But then you get people like Mitchell Froom who's married to Suzanne Vega...check out the album "9 Objects of Desire" by Suzanne...run it through an EQ and watch the lights bounce...Mitchell (I assume it was him, but probably the engineer now that I think about it) anyway, that whole album barely has ANY lights bouncing above like 800 Hz (serious, like the lights bounce up one level {Except for Suzannes breath and SS and "T" sounds})...they all bounce like crazy in the bass region...and every single instrument comes through so CLEAR! AND there are some serious high pitched instruments that just sound SO GOOD! The album does have a warm feeling...but certainly nowhere near muddy.
Okay, I've taken this in another direction sort of...have at it if ya'll like.
PS thanks again for the guitar advice, I'll try different amps...my roommate has a Mesa...I'll see what that does through my 58.
This is one of the big problems with non-tube distortion. It gets too saturated and takes up too much space in the mix. The other problem is when you back off on the gain, it sounds like crap. You need to make your distortion sound 'grainier' instead of 'fuzzier' . That will give you enough room in your mix and most of your problems will go away. Turn the mids up on your amp.
You just figured out what your problem is....you can't get a good guitar sound w/ your practice amp. Are you using the distortion on the amp itself or a pedal/effects unit? You'll never find a good distortion out of a practice amp unless you have a nice distortion pedal.
You next purchase sounds like it should be a high quality distortion/overdrive pedal. That way no matter what amp/speakers you plug into, you have a pretty good idea of the distortion your going to have.
Now after that's done, I'd bet ya that your recordings will slowly improve one you get used to the new pedal. Just remember....use less distortion than you tihnk you should.
Try starting with the guitar track and build the mix around that instead of trying to fit it into the mix. That may give you what you're looking for.
I haven't posted here in a while, but I figured I'd get in on this one.
I have a Fender Hot Rod Deville that never recorded well distorted with the condensors that I have...then I got an MD421 and an RNP. The 10 second test track I did where I just threw the mic in front of the cab and played was better than any distorted guitar track I had ever recorded.
Can you record guitar cab with a condensor? Of course, but if your room sounds like crap it's going to be very difficult. A good dynamic and some nice clean gain will go a long way.
Also, you don't need a Marshall. You need a Marshall if you want a Marshall sound. There are, however, lots of other sounds to be had.
Farview, can you give me an example of a "grainer" guitar recording?
GABritton, I use Digitech and Boss distortion pedals...not the best, but they are pedals. Most recently I've been using the Digitech MetalMaster (I think that's what it's called, anyway, it's the Digitech one, not the boss Metal one...and not that it maters, but I don't play metal...I just like that tone.) I've heard that big ruitar sounds are often put down to tape using small amps in small spaces, that big amps work live, but not so well on recordings. Any thoughts? I've messed with my half stack, and messed with the practice amps...haven't done the half stack thing in a while though, if my info is wrong abour the little amps getting big tone, I'll bust that out again. I guess I should do that anyway to experiment.
Farview, I always thought the metal master gave a nice grainy tone...but now that I'm thinking about it, it might be fuzzier cause it's so smooth...you know? And I think of blues pedals and low amounts of overdrive pedals as more fuzzy...but do I have it reversed? I would think Metal Master would not take up too much space in the mix as it is such a penatrating tone...
EleKtriKaz I find the MD421 to give me too shrill a tone...it burns my ears off...any suggestions on how to use it (right next to the cab, far away)??? I leave the bass roll off all the way on...I don't roll it off at all. Also, I don't combine mics, I only use one and don't know what an RNP is. IS that a good guitar mic?
NYMorningstar I can't beleive I never thought of that...I always build my mixes around the vocal...I get short-sighted sometimes.
Chessrock, I'll try my roomyies mesa and let you know what happens...might be a few days or weeks though with the holidays coming up.
Peace all, thanks for the advice, and I guess expereince will teach me a lot... :cool:
Ignition: My MD421 does not have the bass rolloff. Mine is a fairly old U5 model. I put mine anywhere from an inch to a few inches off the grill and off axis. Has worked well so far, but then again the electric guitars I've recorded with it so far don't drive the tracks.
The RNP is a preamp. My MD421 sounded like absolute poo with the built-in preamps on my Aardvark, but it sounds great with the much cleaner gain from the RNP. It's made by FMR Audio...$475. Do a search on here, you'll find plenty of information/reviews to sift through.
Also, and this is not my own information, I learned it here...you always need less gain/crunch than you think you need...and probably more midrange and less bass.
Also, Also, my Deville does not have a perfect tone by itself...it's always too boomy (this could be due to my room). For me the MD421 perfectly compensates for this. This could be why I like it so much. It may not be right for your room/amp.
Light...that tread is dope. Thanks!
Ahh...the pre-amp...something else to get...I don't use one on vocals....and for the most part, don't have trouble recording them...so I never invested...but know I should.
Anyway, thanks for all the help guys...I know my guitar sound will improve.
Sure I'll be back with more questions...and maybe some answers :cool:
Dude, EleKtriKa, Harvey Gerst wrote a great review of the RNP. I don't know if you've read his posts...but he wrote this one post, I don't recall if it was on this forum or another recording forum,but anyway, he wrote these posts on understanding microphones...but before he would go into detail about anything, he sent us all to this site to read the 60Billion page in depth and technical article about mics....he said, once ya'll got that article underfinger, then ya'll and me will be able to talk shop...and the thread was AMAZING. I learned SO much about mics and mic placement...so anyway, Harvey gave that pre a good review....I trust it completly. Must now run and get one.
http://www.mojopie.com/rnp.html
Peace yo.
